System In Battery Dead
hdj20
F*CK SONY
So i have a 97 grand prix 180k miles on it. Just put a system in and 4th day having it hooked up battery dies while driving. I checked and the wiring from my amp is hooked up to a fuse relay box and not the battery could this be the cause of this?
what i think happened is because the amp was hooked up to to the fuse relay box that killed the battery. does anybody know if this is right?
just hook your power wire directly to the amp. like it should be anyways...then drive around and see what happenes. even if your system drained the battery 100% your alt should keep the car running (that is what the ALT does)
the battery is now dead and thats the cause they said.
They are wrong.
Yes, your amp should be connected directly to the battery with a in line fuse in between. Normally up close to the battery.
No, having it connected to a fuse box in the vehicle will not drain or harm the battery. But running low voltage will.
What are you running?
but my amps not connected to the battery at all just the fuse box. im running a fi q with a 1000 watt amp
It doesn't matter. Are you listening.
The cause of your dead battery is not due to how the amp is connected. You need to charge or replace it then take it to a professional.
Do not take it back to the crack heads who installed your system unless you're asking for your drugs back.
Of course if your amp's REM wire isn't connected to a cut off source and it's always on...
Then that WILL drain your battery.
Of course if this is the case it would be nice if you could mention it.
hdj20
F*CK SONY
hdj20
wisconsin
hdj20
