System In A Ranger
rouskisman
I have a 1996 Ford Ranger XLT, it does not have a cab so there is not a whole lot of space to put in a system without defeating the purpose of the bed. There was once before a system before I got it, there's a hole in the truck leading to the bed. I was just wanting some responses on what you think would make this truck "thump, hit, ....." something like 2 10's or 12's with a good amp and whatever please respond.
Depends on what you want in sound and how much you are willing to spend I got a couple of good 3 10 sub desgins I have seen in rangers.
If you want to use that "blow hole", you can make a box that fits in the bed and put as many subs as you want in it. The RPS (RangerPowerSports) forum has discussions about that sometimes.
Otherwise, with a std cab Ranger, you have to squeze a wedge box behind the seats. You need shallow subs that will work in a small enclosure. IDQ10's or Infinity Perfects might be a good choice but you'll probably still end up losing leg room.
You don't need much power when the subs are in the cab with you. I put a pair of Kicker VR8's in my son's Ranger with 75 watts each and it's enough to give you a headache.
Originally posted by rouskisman I have a 1996 Ford Ranger XLT, it does not have a cab so there is not a whole lot of space to put in a system without defeating the purpose of the bed. There was once before a system before I got it, there's a hole in the truck leading to the bed. I was just wanting some responses on what you think would make this truck "thump, hit, ....." something like 2 10's or 12's with a good amp and whatever please respond.
Putting a 15 in my std cab ranger this week. I easily had 2 Alum10x subs in there and they were great.
hey i drive a 1994 ranger extended cab and just bought a 12" RF HE2 and i dont want to take up the whole back area of my truck cuz i have to take ppl with me sometimes so i was just gonna put it behind the drivers seat, BUT i dont kno dimensions to use to make the box?? which direction to point the sub?? or if i need a wedge box or if i can make a rectangle box?? the only thing i do kno is that i want the box to be sealed...if someone could help out on ne of those questions it would help me out A LOT...thanks
160AH lithium that supports a 12K system is pretty lofty! I've seen dual 24's or quad 12's that will do this. Most of what 've run across is dual...
193
608
Sweet!! Im happy to hear that it was not a major issue.!! Very nice man. Thanks for letting us know what the culprit was!!
19
16
rouskisman
rouskisman
Greenville, South Carolina
matt31
    Jun 1, 2024
    May 31, 2024
