J Jeb 10+ year member Member 85 0 AR Oct 30, 2005 #1 Is there any way to wire a SVC 2ohm sub to two 1 ohm stable amps? Click to read more...
SSS 18734 5,000+ posts Dollar Menu Millionaire 5,614 2 Kansas City, MO Oct 30, 2005 #3 if the amps are strapple, then yes.
skadude016 5,000+ posts CarAudio.com Veteran 7,430 13 Canton, GA Oct 30, 2005 #4 but even then you couldnt make it 1 ohm
SSS 18734 5,000+ posts Dollar Menu Millionaire 5,614 2 Kansas City, MO Oct 30, 2005 #5 well. say you have two strappable amps that put out 1000 watts at 1 ohm. Strapped, they would put out 2000 watts at 2 ohms, meaning you could run the amps to their max potential with the woofer he has.
skadude016 5,000+ posts CarAudio.com Veteran 7,430 13 Canton, GA Oct 30, 2005 #6 well what woofer do you have man? and what are the amps?
