So I did a quick comparison in winisd to see how each sub worked with a passive radiator.
I figured it was the best way to compare seeing as each sub has different needs for port volume.
With a passive radiator I seemed to get pretty consistent results at 3.7 cubes.
I just added mass until the fall off was about 25hz for each.
Each sub is the 15" version, I picked these subs for the comparison because they would each run well off of 2500rms and are top brands that I would consider buying.
Zv.4-RED|XL-WHITE|5200-PURPLE|HDC4.0-YELLOW|ZCON-GREY... From top to bottom
The main question for me is, how does this all apply to real life situations.
Are the Zcon, HDC4.0, and 5200 all very peaky and similar sounding?
Am I dealing with two different groups of subs here?.. are the Zcon, HDC4.0, and 5200 all SPL subs and the Zv.4 and XL SQL?.. it seems I always get one of two type of results when using winisd.
This program really throws me for a loop, I just keep entering more and more woofers into it and I don't really know what to think with the output. Is there anyway I can apply the results to what will happen in real life?
Any knowledge anyone is willing to pass is appreciated, thanks.
