Sundown Audio SAX-100.4
BiaBia
Rated power output
----RMS power, 4 ohm stereo 100W x 4CH
----RMS power, 2 ohm stereo 160W x 4CH
----RMS power, 4 ohm bridged 320W x 2CH
Signal to Noise Ratio >90dB
Low pass frequency crossover
50Hz~5kHz (CH1&2)
50Hz~5KHz (CH3&4)
(50-500 with x10 switch)
Selectable 12 or 24 dB slope
High Pass Crossover
50Hz~5kHz (CH1&2)
50Hz~5kHz (CH3&4)
Variable Subsonic Filter 10Hz to 500Hz
Frequency Response 10Hz ~ 40KHz (+/-1dB)
Bass Boost 0~18dB
Variable Bass-Boost Frequency Control 35Hz to 120Hz
THD@RMS Watts
Channel Separation 75dB
Fuse Rating 30A x 3
Input Sensitivity Variable 200mV~6V (+/- 5%)
Dimensions 252(W) x 58(H) x 480(L)mm
4/3/2 Channel Bridgeable Class-AB Amplifier
MOSFET PWM Power Supply
Stable Into 4 Ohms Bridged or 2 Ohms Stereo Load
Independent 1/2 and 3/4 Channel High Pass Filter Variable
with x 10 Range Selectable Switch
Independent 1/2 and 3/4 Channel Low Pass Filter Variable
HPF/FULL/LPF Selectable Switch
Independent 1/2 and 3/4 Channel Electronic Crossover Slope Selectable
Switch with 12dB and 24dB Octave
Variable Input Level Control
Input Sensitivity : 200mV ~ 6V
Subsonic Filter : 10Hz ~ 500Hz
Signal Input and Line Out RCA Connectors
Multi-Way Protection circuitry (Thermal/Over Current/Speaker Short/Speaker DC protection)
Tested Voltage & THD: 14.4V & Less than 0.05% THD
Operating Voltage : DC10V~16V Power Input
Wired Remote Controller
MSRP $549 USD
$325 shipped, no trades
Item is in pristine condition. The only marks are on the bottom of the amp on the mounting surface (zero dents, just scratched). I've had this amplifier for 5+ years but it's been sitting in storage since Feb 2009. The amplifier has been verified in perfect working condition last week. Have some peace of mind that this amplifier is practically BRAND NEW in terms of cosmetics and usage. The price is firm, you won't find deals like this often.
$325 shipped, CONUS.
I'll ship international if you have feedback or vouches from reputable members (who also have feedback). I'm not in a rush to sell, people asking me to sell for $200 shipped need not to contact me.
BiaBia
BiaBia
United States
BiaBia
