this is soo wrong lmfao.24 sq.in. of port area. is what you need to avoid port compression. a 3" round port is 7 sq. in. so not nearly big enough.
u can ignor that.. what he means in slot ports need to be 12-16 sq in per cf but round ports can be as small as 6 sq in per cubewhat do you recommend? as this is the only box design that will work and size
Its true... 30% more efficent but it acts different too.... its like the air has pressure and the increased compression matters less due to the decrease in wall area... sorry, its something I struggled with as well at first. A round, square, aero and slot all have different characteristics and optimal applications... here is a discussion from awhile back that got me interested in finding out more....How did you determine that? aeroports are at most 30% more efficient than a slot port.
