Sundown Audio SA-10 1.43cuft ported
Hi guys what are your thoughts on 1.43cuft box tuned at 30hz 3" port 13.6" length?
well your #'s are right as long as u subtracted bracing, sub and port disp to get the 1.43cf.. i would tune it to 33-36hz butt thats just me.. if u listen to rap only 32hz is fine if u like rock at all i'd do 34-38hz (35hz tune will play to 29hz safely especially if amp has ss filter) if amp don't have ss filter and u listen to real low bass then u need to stay 32 hz or under just to protect sub
yes it is with port and sub disp.. Do you think port location will be ok it will have a 90 deg as well?
as long as neither end of port is blocked (need couple inches free on each end) remember u can have port come out of box as far as u want, may look stupid but thats up to u.. if u leave 2" sticking out u can add to it and change tuning easily..
t.j
t.j
u.k
BOOMINGRANDPA
