sundown 3k or stetsom 4k2d?
I have not tested the 4k2d personally to do a direct comparison but I would not be surprised to see similar reactive power from the 3000D at 1/2 ohm vs. the 4k2d wired at 2 ohms based on my testing of the 2k5d model.
i put a 4k2 at 2ohms on my omegas and my 3250 at .5 and my 3250 was 1.5db louder. thats why i said the sundown over the stetsom
Since the 3000D would have to be purchased used or refurbished I would guess the 4k2d is also going to be a good bit more expensive... so my question is, do you have a budget ?
Also... the 4k2d, as stated earlier, is a 2 ohm amp so is not directly comparable.
4k2 is 660+shipping from Brazil so about like 750shipped i guess. quoted from steve in maryland
lambofgood91 has one he might sell, then teamsuthernbass has his 3k for 575shipped
To be "apples to apples" the 4k2d would need to be at 1 ohm as it is a 2 ohm amp (half rated impedance like the 3250 at 1/2 ohm).
If the OP has a choice between 1/2 ohm and 2 ohms only then it seems as if the 3000D would produce more power -- if he could run at 1 ohm the 4k2d could quite possibly pull ahead, but I'm not sure that Stetsom would recommend that load "daily" on the amp.
Freight from Brazil is nearly $200 there cheif //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
nG
wow........... interesting.......
//content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif that shouldnt be the case but at the same time.....
never know
Yea i was REALLY surprised too...... We didn't clamp it or figure imp rise or anything but his 3250.1 compared to my 4k2d was a good bit louder on the meter and too the ear. And maybe its just my luck, but my 4k2d seems "protect happy" if u get my drift. It's very picky, goes into protect with any voltage over 14.5. I'm pretty scared to drop it below 2ohms, even with imp rise i would still be nervous. So i would say go with the sundown, i think I'll be making the switch myself sometime soon //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
sikcavy
sikcavy
Winslow, ME
sikcavy
ThxOne
    May 13, 2026
ThxOne
    May 13, 2026
