sundown 3k or stetsom 4k2d?
idk my last amp would drop to 9.2 volts and never fryed ...steve the north american rep said himself that below 10v that the amp will most likely burnup...hes doneit himself...i have nothing aganst thair amps but for what hes trying to do with it i just dont think it would be worth the money
So u guys have daily systems that drop below 10 volts?
Thats just a poor electrical system. You cant blame an amplifier if it fails below 10 volts.
I've used quite a few Stetsom amps for daily, and none of them have ever failed me.
http://www.caraudio.com/forum/showthread.php?t=412874&highlight=stetsom+4k2d
This weekend was the first time I finally got to test the 4k2d on good electrical from another person car and we got 5000w 12v running it a little less then 1ohms rising to 3-4ohms. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif I'll admit it's not the most efficient amp on the planet but for size that totally makes up for it in my opinion. Even with minimal electrical like you see here over 3000w at 4.5ohms after rise is still crazy. Besides the fan being a little noisy it's the craziest best sounding little amp I've every tested
Since the 3000D would have to be purchased used or refurbished I would guess the 4k2d is also going to be a good bit more expensive... so my question is, do you have a budget ?
Also... the 4k2d, as stated earlier, is a 2 ohm amp so is not directly comparable.
it would be a 100 dollar difference between the 2. also i understand but once the 3000 is wired down, it should put out close power shouldn't it? wired to around .5
sikcavy
sikcavy
Winslow, ME
sikcavy
vegang
vegang
