Sundown 2012 Frames : Samples Arrived
sundownz
Pro Seller
Supporting Vendor
The samples arrived while I was out of town -- back now and on to the photos !
Weights :
10" 12-spoke : 1.7 lbs
10" Sundown : 4 lbs
12" 12-spoke : 2.3 lbs
12" Sundown : 5 lbs
15" 12-spoke : 3.4 lbs
15" Sundown : 7.9 lbs
Not a finely calibrated scale so within a few tenths.
* THICK rim -- no more cracked rim with over-tightened screws or with a super heavy motor.
* THICK base -- no worries about bolts pulling through even with motors 2-3x heavier than we use now.
Still awaiting our new cones and surrounds to arrive... then we can do some building and show off what these can do !
Mocked up on a motor with our new spacer ring... very similar to the Z v.3 18" spacer but the ID matches our new frame base and this one is a bit thicker to allow a bit more air flow as the new frames have more displacement potential. The same spacer works on all sizes 10/12/15 as well.
* Inner air passage on spacer
* Outer air passage
* This is a 12" frame and motor mock-up; proportionately looks alot like the SA-8 v.2
Can't say I'm in love with non-standard spider sizes, but they sure look nice and functional.
You can glue an 8" spider to any of them still //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif They have multiple landings -- but our 8" landing is over-sized to also accept the 8 3/8" model.
There is enough glue pad that most 8, 9, and 10" units will glue right on.
Can't wait to order a couple baskets cones and spiders. Are the spacers the same. For all baskets or each basket have a different Spacer?
Flexibility is great. Thank you for pushing some innovation.
sundownz
Pro Seller
Supporting Vendor
sundownz
North Carolina
Mitch86
