Suggestions on single 10 with a Rockford 300x1 amp
customlt1
PBR300X1 on Rockford Fosgate's website):
75 Watts x 1 @ 4-Ohm
150 Watts x 1 @ 2-Ohm
300 Watts x 1 @ 1-Ohm
Been running this amp with an old alpine type R. Sub finally took a dump so it’s time to get a replacement. I want to power the sub/amp correctly. It’s in a sealed box, the car is an Acura TL. I’ve always liked JL but open to options! Not trying to spend more than $200 new.
PBR300X1 on Rockford Fosgate's website):75 Watts x 1 @ 4-Ohm
You need a dual 2 sub .. I may have something
https://www.sonicelectronix.com/item_94036_Image-Dynamics-ID-10-D2-V.4.html
Or the audiofrog g10d2
https://www.crutchfield.com/S-fhByeJHEVms/p_898G10D2/AudioFrog-G10D2.html
What kind of specs should i look at for that type of amp in a ten? 300 watts max at 2 ohm?
I have the next model up I could sell you, the gs10 but it is dual 4. A dual 2 is really what you need obviously.
What kind of specs would I need to look at for a 10 sub with that amp combo? 300 watts max at 2ohm?
u said your amp does 300rms at 1 ohm.. if true u need a d2 sub with pretty high db rating and works well sealed that ID he showed u should be good..
You must have had the gained turned up way too high if you blew that type r on that tiny little amp. Learn how to set the amp controls before you buy another sub or you'll just blow the next one.
I didn’t blow it, the outer seal came off which is attached by what looks like glue. It’s old I’ll swap it
10
311
front doors are subs...fyi Go with AudioControl 6x9 components up front and coaxials in the rear. You will be impressed with just changing to that.
299
If you can find these in your area. Id recommend these for drop ins. They play from 40Htz on up. Sound very nice on amplified power for premium...
You might get some inspiration from the install that I did... Delta Audio Install
883
Hahaha his brother got some from a friend. American bass amp and some alpine s 12in subs. From a buddy of his now Eastons chomping at the bit...
539
customlt1
customlt1
buffalo,ny
THATpurpleKUSH
GoldCountryCA
    May 5, 2024
GoldCountryCA
    May 5, 2024
