Suggest me a sub....
lowriderram_95
VW Surgeon
Looking for a 15" that will work in a 4 cube box tuned to around 38hz. Must wire up to 2 ohms. I will be buying it in a couple of weeks once I start my new job I'm just lookin for some suggestions on what I should look for. My budget is going to be around 200 and it must be able to take 900-1000 daily.
i dont have expeirence with the 15" but i do with the 2510. i ran mine on 1k daily and it was very impressive and took the power with ease. the 15 has the same coil and motor so i would have to think it would be a beast with your box suggestion and power.
-vic
thanks for the suggestions guys, oh and about the RE SE...I had one but it must have been effed up from the factory bc shit kept goin wrong with it. Had to re solder the tinsels, reglue the spider, then it just decided to quit working. Didn't think I could blow an SE with a 750.1 but I did. And yes I did set the gain correctly with no bass boost.
SDC2.5 15 (we run a 12 on 1700 daily) Mach 5 Audio IXL 15, ( I had the 18 as my HT sub on 1000watt for over a year, Incriminator Audio LI 15 (only rated for 600 but Nick under rates all his stuff we burp our DP's at 5K each), Ascendant Audio Chaos 15
lowriderram_95
VW Surgeon
lowriderram_95
Little Rock, AR
lowriderram_95
