subwoofers Xsite
joen
Good afternoon my name is Jorge and I am of Ecuador, I write this mensaja to him to do consultations and hope to him can help me.
I have two subwoofers of the Xsite mark model xs1285 with the next specifications:
bajos Xsite 12" 1000 watts RMS
modelo xs1285
12" ultra high excursion site spl subwoofer
99oz. massive bouble stacked strontium magnet
power handling: 1000 watts R.M.S.
frequency response: 30 hz - 500 hz
efficiency: 92.5 dB
3" aluminiunvoice coil former
Fs (Hz) 36.3
Qms 7.5
Qes 0.854
qts 0.767
Vas (liters) 56.5
Vas (cubic feet) 2
EBP 42.5
Revc (2 each @) Ohms 3.6
SPL (1w-1m)dB 92.5
Xmax (mm) lineat peak-peak 10
caja cellada minima (pies cubicos) 0.75
caja cellada maxima (pies cubicos) 1.5
caja ventilada (pies cubicos) 2
3dB down point (Hz) 32.85
Vented to (Hz) 36
port Dimensions 4 x 9.25"
and my restlessness is, whereupon amplifying I must connect them… I have three options:
1. - Xsite xad2k
1 x 2000W @ 1 ohm
THD: 0.05%
S/N Ratio: >100dB
Freq. Response: 25Hz ∼ 200Hz
Dimensions: 17.71" x 10" x 2.17" (45cm x 25.4cm x 5.5cm)
Class D Circuitry
2000 Watts @ 1 Ohm
Multi-Stranded Power
Supply Toroids
Blue Anodized Heat Sink WIth
Lazer Diamond Surface
Brushed Aluminum Case
Remote Bass Control
THD:0.05%
S/N Ratio>100dB
Variable Sub Sonic Filter: 15Hz-40Hz
Variable Phase Shift: 0-180°
Variable Bass Boost Control:0-18dB
Frequency Response:25Hz-200Hz
Tiffany-Style Input & Output RCA Jacks
Milspec Double-Sided Epoxy Circuit Board
Data Link Port (Combines 2 Amplifiers Into a Single Output)
2. - Xsite xsd1200
Class D Circuitry
1200 Watts @ 2 Ohm
Supply Toroids
Remote Bass Control
THD:0.05%
S/N Ratio>100dB
3. - Fusion FP 1000 D
1 Ohm / 2 Ohm Stable Linked
CEA 2006 Amplifier Power Standard Compliant
FUSION Regulated Amplifier Technology (F.R.A.T)
FUSION Intercooled Semi-conductor Technology (F.I.S.T)
FUTRANZ Efficient Heat Sink Transfer Technology
Gold Plated 4 gauge Power and Ground Connections
Gold Plated Audio Input and Output Connections
Gold Plated RCA Output for Multi-purpose installations
Compatible with FUSION bass control remote
Product Specifications
Bandwidth 10Hz - 250kHz
Signal to Noise >95dB
Fuse Rating 3 x 30A
Separation >60dB
Input Sensitivity 300mV-8V
LP Variable Crossover 40 Hz - 240Hz @ 24 dB / octave
Variable Bass Boost 0dB + - 12dB Gain @ 45 Hz
Variable Sub Sonic Filter 10 Hz - 50Hz
Input Impedance 20K
Damping Factor >200
T.H.D 0.05%
Dimensions D 57.5mm L 220mm H 220mm
CEA 2006 Compliant Amplifier Ratings
12.6 Volt Power Output Specifications
450 WRMS per Channel @ 4 Ohms and 1% THD+N
725 WRMS per Channel @ 2 Ohms and 1% THD+N
1050 WRMS Bridged Channels @ 4 Ohms and 1% THD+N
14.4 Volt Power Output Specifications
575 WRMS per Channel @ 4 Ohms and 1% THD+N
1000 WRMS per Channel @ 2 Ohms and 1% THD+N
1400 WRMS Bridged Channels @ 4 Ohms and 1% THD+N
Linked Power Ratings @ 14.4VDC
1650 Watts RMS Linked @ 4 Ohms
2550 Watts RMS Linked @ 2 Ohms
I hope and desire you can respond to me of the way but it makes specific and fast… on purpose you can help me with the measurement of the box for both low, I want a box model bass reflex…
Beforehand express my gratefulness and will wait for your message
yeah Ive got a couple of xsite amps sitting around here, they're pretty much Audiobahn equipment. From me just popping the top on them and looking at the motherboard, they dont appear to be too badly designed.
be very careful on the amount of power you give the subs, i had two of those same in the fifteens and had them on 500 each and they blew, they sounded absolutely horrible too. Hopefully yours dont.
joen
joen
Ecuador
ThatChevyGuy
