Subwoofers Aren't As Loud as Yesterday
So, with those two subs how much wattage would I need? I believe they both have a rating of 150 RMS, so I need an amp with around 150Wx2 RMS @ 4 ohms right?
no, you want a mono amp. Meaning one channel, then you wire the subs together. Will be a cleaner sound, you get a subsonic filter, and use less power to make the same wattage. Look for a 300-500wrms @ 2ohms rating from a quality amp.
you will wire them together for a 2ohm load.
verify every single point of termination and connection along your power/ground wire path. may or may not find something, but you will benefit from checking and tightening all connections regularly
I already did that and I tightened everything up, but that is not the issue.
---------- Post added at 03:11 PM ---------- Previous post was at 03:11 PM ----------
I think i am going to invest in a Rockford Fosgate 500W RMS x 1 at 2ohms
if its more expensive than whats been listed, youre wasting your money on the rf name
On Ebay it is $130 for the RF R500x1D, and I think that's the one I want to go with because I don't really want to spend over $140 right now.
if thats new seems like a good enough deal to me although the rockford prime series of amps are just the same as almost any other board within that price range
im not calling them bad, just letting you know where they are in the foodchain
the FSD audio amp i showed you its 700wrms at 1 ohm and around 500 at 2. So more then enough power for right now then later you can get bigger subs in single 2 ohm or dual 4 ohm and get 700 from the amp.
Its 140, better then the RF for sure
Lighten up man, it's all in good fun. Having more to go on than I want a sub that is less than 6" deep heps the forum narrow the focus. Why...
951
Adire Brahmas were incredible subs. One of the first subs that could really compete with the JL w7s. Super flat BL curve gave the subs a really...
928
Placed a pair in a an enclosure according to enclosure specs below on a Crescendo Skyway 3k and they seem to be doing very nice and really...
Cool down, bro. and have a happy thanksgiving. I was merely inquiring in response to someone else's post that cautioned about clicking on the...
Darkspartan239
Ocala, FL
Jeffdachef
    Apr 26, 2024
    Apr 26, 2024
