Subwoofer wiring help
wire the subs up so its a 2 ohm load then only use one set of the outputs on the amp. bridge. that is if it has two outputs..if only one just hookem up to that
the amp has 2 pos and 2 neg to make wiring easier they are connected internally.
with your subs you can only have 1 ohm or 4 ohm at the amp.
dking_boss
dking_boss
Sierra Vista, AZ
SicAudio
