Subwoofer to go with Rockford punch 800a2 - Need Advice
Cheezledzul
Can anyone advise me on what subwoofer I should run with this amp.
Thanks in advance
Parameters:
10"-12"
Single Sub
$200 or less preferred. Although I can go a little above if necessary.
*** I am looking for a very crisp, clean sound. I dont want a muddy sound and will not be blaring it to the max.
I listen to a lot of 80&90s rap/hip hop as well as edm (think more mainstream like carnage, Swedish house mafia, hardwell, zedd etc)
Current Setup
2014 ford focus hatchback
-stock 6 speaker setup
-stock head unit (may upgrade in the future)
-Rockford punch 800a2 amp
The music is for my enjoyment if that makes sense, not the public.
Amp specifications. (I don't really know what I'm looking at)
Rockford Fosgate Punch 800a2 200 x 2 Car Amplifier at Crutchfield.com
http://www.rockfordfosgate.com/rftec...nch2ch_MAN.pdf
I see a lot of brands that are not the usual alpine, mtx, ken wood, Bose, JL, etc.
Is there a reason why
built better, lasts longer, more motor force for controlled excursion, higher Xmax, lists actual Thiele small parameters so designing an optimal enclosure via winisd pro is much easier. Handles as much clean power as you can throw at them without croaking. Louder and sounds great. JL w6 and w7s are nice sounding woofers but a dub7 is not an 800$ woofer
These are 800$ woofers.
http://www.caraudio.com/forums/subwoofer-classifieds/606015-fs-ermagerd-protos-12-15-18-a.html
Sundown Audio Nightshade v.3 12" 2500w RMS Subwoofer - SSA STORE
The c2 threatcon I mentioned has a similar sound to a JL w6 but can get louder and its at 1/3 the retail cost.
I see. I figured it was the typical name brand sells better. But I haven't seen any of these brands anywhere. You would expect them to be a little more known.
Any other opinions?
I would like to hear some more opinions so I can actually do some comparisons.
Is that 800 watts bridged @ 4 ohms? If that's the case, whatever sub you choose, get dual 2 ohm coils so you can wire to 4 ohm easiest.
I would recommend a Rockford Fosgate P3 12" since it matches the amp. Ported box tuned to mid-high 30hz range
Is that 800 watts bridged @ 4 ohms? If that's the case, whatever sub you choose, get dual 2 ohm coils so you can wire to 4 ohm easiest.I would recommend a Rockford Fosgate P3 12" since it matches the amp. Ported box tuned to mid-high 30hz range
Here is the info from one of the links
stereo, bridged mono, or Tri-Way output
800 watts x 1 in bridged mode
400 watts x 2 at 2 ohms
DSM technology
I can get my hands on pioneer ts 303w 12" subs?
Would these work well?
Are they the quality that I'm looking for or should I just get something new
I wouldn't spend the money on those but I would go with one of the subs listed above
mainstream commercially marketed equipment is what you know
non-mainstream non-commercially marketed for the masses equipment is what is being suggested
the choices of non or main is not a choice unique to car audio but exist in all goods, and the heads of these type offerings are usually very passionate users/competitors themselves
I figured that was the answer. Do you suggest anything in particular?
The rockford sub I mentioned would be free. I don't mind spending some money tho
Is the amp I have even good or decent? Or is it low end garbage
This is a bad *** amp. Well built and built to last. I ran one daily at 2 ohms stereo for 2 years (when the amp was 13-15 years old) and it never gave me a single issue. I sold mine earlier this year and I immediately regretted doing so.
Google and Ebay are your friends. Froma quick search and providing these are like new, $2- $400 for the subs and $2- $400 for the amplifiers...
dragon.breath, Many thanks for taking the time to help me out. It is very much appreciated and my small brain can understand it now. I have...
760
To do this magic, should the microphone always be kept in the driver's seat or on the dashboard?...since that is where it must go in phase with...
LOL. Ya man. Its been busy. Im off today, but got stuff to do around the Casa.Be a Great sub man, and very nice amplifier. If you can swing a few...
18
Open screw holes sound like a little muffler, loose box panels sound like a massager on a wooden table.
20
Cheezledzul
Cheezledzul
Rockland NY
Cheezledzul
