subwoofer terminal trouble
loud-n-low
i give ladies 30mm xmax
I have a dual 2 ohm sub.both coils are perfect,read out at 2.0 ohm each, problen is the screw type termanals keep losing contact no matter what i do. they are connected to a plastic piece and they dont seem to come off,I wanted to see if they came detached from the lead wires or whatever the hell else. this common with screw terminals?
take a pix and post should be easy fix but there is several terminal types. should be able to tighten the nut on top easy..
top nuts look tight, wondering if the leads need to be resoldered...hey! your local,want to help?
loud-n-low
loud-n-low
upstate NY
loud-n-low
michigan born
    May 14, 2026
michigan born
    May 14, 2026
