Subwoofer Suggestions to match amp
Sealed at MAX dimension will probably SOUND louder than Small ported
But it wont be a small ported. I have space to put up to 5cu ft enclosure. depth of box doesnt matter as long as you have proper volume does it?
---------- Post added at 02:35 PM ---------- Previous post was at 02:35 PM ----------
1 cube box with an SPG555. do it.
Ugly sub, completely out of my price range.
that should work if not sub up, you might want to look at putting port on side so you have more length of air travel, bottom port might not work right, im assuming your box will be wider, higher and thinner right?
From the dims you gave earlier, i got 3.8 cubes, unless i missed something
Edit: you didn't take into account you will need atleast 3/4 inch would all around. It comes out to 3.81 internal volume, before sub and port
Skar is made for lows, so if you put it in a sealed box it would get down really good, and you are saving some space. I also have a kid and this is the reason why i am thinking of putting my skar vvx 15 on sealed box
You said budget of 200... they can be found for about 50 to 100 more, not sure what you mean by ugly sub?
Needed: Advice on either 2 -8" or 1 - 12" sub to match a Eb nine.2x
Amplifier Specifications
200W x 2 @ 4 Ohm
300W x 2 @ 2 Ohm
600W x 1 @ 4 Ohm
Detailed Amplifier Specifications
Signal to Noise Ratio >95dBA
Variable Input Sensitivity 150mV - 7.0V
Remote Variable Input Sensitivity No
Variable Low Pass X-Over 40-240Hz @ 12dB/Octave
Variable High Pass X-Over 40-240Hz @ 12dB/octave
Current & Thermal Protection Yes
Remote Gain Control No
Variable Phase Control No
Master / Slave Option No
Efficiency 67%
Variable SubSonic Filter N/A
Fuse(s) 3 x 30A
Max Current Draw 85 Amps
Damping Factor 300
Budget $200.
Enclosure will be custom made to match sub(s) purchased.
This will be placed in a Yukon. Third row seats can not be removed for more space since my son takes several other friends and family to school with him. So this limits depth of enclosure to about 10 inches.
What will match that amp and give the loudest volume for the budget?
a Diamond D612 D2.
Hjbennett
Hjbennett
Yazoo city, MS
Hjbennett
