Subwoofer problem
Objektiv
So i just got a pair of aq hdc3's. I hooked them up and noticed when sub sounds like complete shit, and when i push down on the cone, it scratches. The other sub is fine. It plays ,gets loud, and reads on the ohm meter, just can hear the scratching when it plays, like a terrible rattle. Any ideas?
ok so i got the sub out the box and played it, and it seems like the noise is comin from the spider having a small gap where it connects near the cone, you can tell it was previously glued and it looks like some excess glue and part of the spider has loosened up and rubbing against the cone , any kind of glue i could use to seal it back in place at least for a temporary fix?
While you've got it out, I was curious if you could take a picture of the issue?
i use amazing goop in the blue tube to hold my triple joint together //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif works good till i strap the AQ's to the 12. i use Qtips to slowly squash it in there
ill try and get the best pic i can, you can tell the spider is all tore up, were the tinsel leads are on one side , i can peal a inch by inch flap of the spider back
Objektiv
Objektiv
Appleton WI
Objektiv
ThxOne
    May 13, 2026
ThxOne
    May 13, 2026
