subwoofer helpp
you have 700 and what guage power wire, you could do a 12" ICON and Sundown SAZ 1000D for $499 from SSA and get a bunch of 1/0 hyperflex and maybe an extra battery. propper 700 usage.
12W1 is the lowest line of JL audio you can do much better!!
the Icon would PWN a pair of 4500 and your gonna double the wattage while your at it.
Sell the Alpine here and yor only out like $500
or if you have the power wire at least 2 guage you could do 2 12" sundowns on a 1000D for $689
http://www.soundsolutionsaudio.com/shop/index.php?act=viewProd&productId=341
If you went AQ you could get a 1200 watt amp for $250
their SD 2.5 12" are only $139 each and are 600rms with over 2" of useable throw.
http://www.audioque.com/aq/SDC2_5_Series.htm
these are solid options you will get more from others on this site.
for mostly SPL get a 15" L7 and the AQ 1200 watt amp the L7 shoud run $300 at most and then build big box tuned to 40 and hold on to your eyeballs.
hmm yea i was wondering about those JLs bc they r the lowest ones or w.e.
so if i got the AQ amp and one 15'' L7, that would be about 550$ roughly?
will that one 15'' hit harder than my MTX. i mean i no it will but how much of a difference will i expect
you put 1200 watts on a 15" L7 and it shoulde be like 3 times as loud to the ear, you have twice as much power moving a much larger cone, with a medium ported box it should be much much louder thatn a 4500. Carefull with the gains might want to set the output with a dmm to be around 1k - 1200 and watch the cars voltage. The correct enclosure is just as important as the sub and amp so dont skimp out or get prefab.
Thechad1989
Thechad1989
Jacksonville, Fl
skateboardkid
BP1Fanatic
BP1Fanatic
