subwoofer cutting out??
If it cuts out only on heavy songs You prolly mean low bass. Alot of people who have voltage issues low bass is when it will cut off. Must pull more current than higher hz tones.
Anything that has constant bass like rap song it will cut out then come back on then cut out an come back on. Stuff like Pitney an some reggae its fine though
---------- Post added at 09:52 PM ---------- Previous post was at 09:51 PM ----------
Yea keep it down til u get a alt
---------- Post added at 10:21 PM ---------- Previous post was at 10:21 PM ----------
U got all that nice equipment ..give it some real juice
Cool as long as you guys don't think there is damage done then I'm relieved
Should be fine that what protection circuitry is for..get.a alt asap
Yea def not ok. Find out what/why that fuse holder melted and fix it ...then get ur electrical in check... i used to have a bc3500 and had to put my stock alt back on 125a while my mechman was being repaired ..i had a 55ah duracell up front and 2 110ah dekas in the back and it was not a very happy healthy setup..start sacin pennies and pray the bc didnt fry
well I figured out the problem. First off the amp was mounted on the back wall of my extended cab truck behind the seats and it fell off. But changing the burnt wire (which was due to the heat sink melting on the fuse block) fixed the cutting out issue. But im definitely getting a new alt asap after everything you guys said. thanks again for all the help
---------- Post added at 01:33 AM ---------- Previous post was at 01:33 AM ----------
---------- Post added at 01:34 AM ---------- Previous post was at 01:33 AM ----------
You have nowhere near the electrical to handle that much power.
/thread
Justin braaapp
Justin braaapp
Torrance CA
Justin braaapp
