Subwoofer Box Design Info
The box has 2 chambers, each chamber has 2 10" subwoofer holes, and each champer is 1.1 cubic ft, should each chamber be divided again?
1.1 per 10" sealed is a bit on the large side, but if you have it built already then wire it up and try it. With out knowing what subs you have there is no way to say how it may sound or what you should do. You only need two chambers though..you just may have to much air space per chamber.
He's saying it's 1.1 for a pair of 10s. His box is 2 chambers and each chamber is 1.1 cu ft with 2 subs in it. So it would be around .5 per sub if he were to put each sub in it's own chamber.
Phillips_211
Phillips_211
Augusta, Ga
Phillips_211
