subwoofer bandpass box questions.
carter1010
Hello all, I have some questions about bandpass boxes.
Can any subwoofer work in a bandpass type enclosure?
How do you know if a sub is optimized for use in a bandpass system?
I have an existing bandpass box that had a sub in it, is there a way to identify what size the box is and what driver would work best with it?
Thanks in advance.
Thanks in advance.
There are a few things that can flag it. Which woofer is it? Bandpasses are possibly the most complicated box to design, but if you post the TS, I could screen shot some results.
I have the same question. I want to know what to look for to say if a bandpass will work. I was told to look at fs/qts and if below 50, sealed and bandpass work. I got these clearance woofers from a speaker builder and they said 0.5 sealed but could go band pass. Here are the specs they sent me, what do you think?
Power Rating RMS Cont. 250 Watts
Max Power Rating-Unclipped Amp 350 Watts
Freq Response 25-150 Hz
Nominal Imp 8 Ohms
Voice Coil 2" 4 Layer
FS 25.18 Hz
Qms 8.8040
Qes 0.3579
Qts 0.3439
Vas 67.30 Liters
Cms 0.3994E-03 M/N
Re 6.93Ohms
BL 17.505 Newtons/Amp
Sd 0.034636 Sq. m.
Mms 0.100017 Kg
Hvc 0.980"
Hag 0.375"
Xmax 0.303"
Xlin 0.605"
Ref Eff 0.2885%
Predicted Output 86.802 DB/1W/1M
I have 2 tens and was thinking 4th order wired to 4 ohm load.
the sub that was in the bandpass box was JL 12w3. It was not made for this box, someone had a bandpass box and threw a W3 in it. The box demensions are 9.5 x 13 x 13 sealed side, and 15 x 13 x 13 ported side with two 4" x 7" diameter ported boxes. I know its a generic ported box, but its a pretty nice enclosure and I would like to put an appropriate driver in it.
Thanks again!
That comes out to .9 cuft on the sealed side and 1.5 cuft on the vented plus the 4" x 7" tubes. Any suggestions as to how to figure out if a sub will work in this. Leaning towards an RE but not sure if they will work. Suggestions please?
dont weaker subs generally benifit from pre-fab bandpass boxes? my 2 Type R 12s that i just bought came in a Qlogic BP and it sounded whack. i figured some cheapo 12s would be better though if i decide not to sell that box..
You build your box for your sub. A sealed box is pretty easy to match up, the more complicated it gets, the more difficult swapping drivers is. With a bandpass the type of driver changes what kind of sound you get Alot. Pull up winisd and play with it some. The box can be designed for output or make relatively flat sound.
yeah i get that stuff, but i was just under the assumption that most pre-fab, best-buy, bandpass boxes are made so that low end subs can get louder. a sub with a lot of displacement and power wont generally do as well in those boxes as the lower end subs do. i know BPs can be made to make beefy subs loud as well, i was just talkin about those pre-fabs.
Band pass boxes are usually the most efficient wattage wise, for almost any speaker (but they're very large). The trick is that some speakers do better in them than others. You also compromise the lowest bass to do it. They're also complicated to design, and no pre-fab will be any good, unless some random luck allows that to happen.
Band pass is probably the hardest to build, as well, aside from transmission line, so a pre-fab could have all sorts of problems with it. On top of all of that, a pre-fab will generally have inadequate port quality, and some subs might literally tear the box apart, or will tear themselves apart, due to incorrect tunings.
Essentially, you design a band pass after lots of double checking of all the math. You can't just put a woofer in a bandpass and expect it to sound good, let alone not rip itself apart.
Jroo, I'm working on your specs. I should have time to sort it today or tomorrow.
Google and Ebay are your friends. Froma quick search and providing these are like new, $2- $400 for the subs and $2- $400 for the amplifiers...
dragon.breath, Many thanks for taking the time to help me out. It is very much appreciated and my small brain can understand it now. I have...
500
To do this magic, should the microphone always be kept in the driver's seat or on the dashboard?...since that is where it must go in phase with...
LOL. Ya man. Its been busy. Im off today, but got stuff to do around the Casa.Be a Great sub man, and very nice amplifier. If you can swing a few...
18
Open screw holes sound like a little muffler, loose box panels sound like a massager on a wooden table.
20
carter1010
carter1010
Charlotte NC
bladebarrier
    May 16, 2024
    May 16, 2024
