Ok so I know people will be disappointed in me but I bought some
Kicker CompVR 400RMS/800Peak subwoofers. They were only about a hundred dollars each, and well I have a lot of credit at Brandsmart and am trying to build my credit so being that technically they are the next step up from the
standard Kicker 12" Comp 140RMS/300Peaks subwoofers I had, I bought them. Walked out the door with them for nothing. 6 months to pay them off. Anyways,
the problem is while i was replacing the standard 150RMS/300PeakKicker Comp 12"s for the CompVR'S I noticed there were four plugs in the back to hook up the wiring instead of two. I was told only to hook up the plugs with the dots and leave the other two alone because my amp would not be able to take the pressure, but my first instinct was to
add additional wire from within the box and hook up the other two via a splice. Again, I was told these are
Dual-Voice-Coil speakers. They sound better than the standard Comp 12"s I had already without the additional plugs being attached. I need advice on what I should do next though, I really want to hook the speakers up all the way.
Any advice? What would happen if i tried to get the additional wiring and connect the other two outlets on either outlets not being used via the cables in the box?
Do I need to get a new amp or change the settings on the one I have.
The specs of my amp are Kenwood Kac-7204 1000w (RMS X2 at 4 Ohms)
Kenwood KAC-7204 2-channel car amplifier 170 watts RMS x 2 at Crutchfield.com
The specs on the new Kicker CompVR subwoofers are
CompVR | KICKER
Size (IN.,CM) 12, 30.0
Impedance (OHMS) 2 or 4 DVC
Max Rec Amplifier Power (WATTS PEAK/RMS)* 800/400
Sensitivity (dB 1w/1m) 86.9
Frequency Response (Hz) 25-500
Not sure what to do next, but if you are not positive please don't offer advice if you are taking a guess. If I have to upgrade my amp any suggestions of which one I should get? Thanks, I've been researching everything you guys have said so far. Thanks so much.
