Subwofer help needed
Emo
Ok, I picked up a new/used subover the weekend. Once installed I ran across a problem. The subs sounds distorted when playing, but if you place alittle pressure on the cone (slightly holding it) the sub sounds normal. I'm not sure what the problem might be. I do not want to blame the seller just yet, because this might be an enclosure issue. The sub sub should work with a box from .5-1.25 cuft. Basicly without the pressure the sub seems to have zero control and the box is perfectly sealed. Any suggestions????
Emo = Nickname not lifestyle
Sub is rated at 300w was receiving maybe 200w. So I do not believe that is the problem. Amp has been working without any issue for a couple yrs I do not think its that amp. Any more suggestions??
Emo
Emo
Tucson Arizona
lincolntc690
