Subs working barely. PLEASE HELP
Ok, I'm going to assume that you have two single 4-ohm subwoofers. Look for an amplifier that will produce approximately 400-600 watts RMS (somewhere in the middle would be perfect) with a 2 ohm mono load. I'm not sure what kind of budget you're looking at however.
What about a Kicker KX600.1? Ikesound has them for 240 refurbed. Slightly less expensive is the Phoenix Gold x600.1 for 225, also from Ikesound.
These are just quick and dirty suggestions, I haven't been looking at amplifiers recently so I'm not really sure what all is out there. Find out the wiring configuration of your subwoofers. You might have dual 4 ohm subwoofers which means you have to look for an amp that will be stable at 1 ohm for 500 or so watts into one channel or an amp with similar output at 4 ohms, both of which will be likely to run you a few bucks more.
A little more information might help us out a little bit more.
Well, Im not really worried about wiring, my dads a car dealership manager and has over 20 mechanics that work for him. So basically I can get someone else to do it if its hard. Also Im going to IM you on AIM imaspaceguy
tzk0nlin3
YoUr FathEr
tzk0nlin3
McKeesport, Pennsylvania
skadude016
ThxOne
    May 13, 2026
ThxOne
    May 13, 2026
