Subs to amp install, need help!!!
netherland ur all about ur kicker L7 question every post i go into ur askeing the same question. just go with the 2 12's which is like having 2 standard 15's dont mix them. they will be plenty loud
The amp is bridgeable. You should be able to connect the 15 across both channels, from one channel + to the other channel's - terminal (follow the manual). As long as all subs are 4 ohm you should be OK. Note that Sony amps tend to go into shut down mode if you overload them, so don't expect a whole lot.
i hooked it up...both the 15" and the 2 12's...it pounds like crazy
that 15" makes a big difference!!!
i just hope the amp doesnt xplode....(get it)..lol
there is a funny smell in the car tho..like a burning smell...what do u ppl think it is???
do u mean the gain??..if so..they no its not..the gain is only half....i dunno what i could be..i kinda smells like when ur using a hot glue gun....it smells like the burning glue..its coming from the front..i hope its nothing with the deck...cause its fairly new..only bout 2 months or so
robo519
robo519
Canada
g30ffr3y
