Subs to amp install, need help!!!
why isnt it good to mix subs...my buddy has 2 12" and 2 10" subs, runnin off a mono amp...
does it still matter if its off a different amp?
It really doesn't matter. But the efficiencies, volume, frequency ranges etc will all be different and the system could be difficult to tune.
To answer your question depends on what impedances the subs are (2 ohm, 4 ohm, single or dual coils, etc) and what the output impedance capabilities of the amp are.
the 2 12's are kaption HD-124/8 (250 watt) they are setup as 4ohm. and the 15" is a orion 500watt, i think its a dvc...not sure...and the amp is a crappy 1000watt xplode 2 ch.
you can wire whatever ohm speakers together. it will just give you a funky ohm ohm load and you amp might not be able to run at that weird load.
here is how the subs are hooked up to the amp....i wanna know where/how i would hook up the 15"
the 12s are
kaption HD-124/8
the amp is a Sony XM-2165GTX
the the 15" is a orion (500watt)...dunno the model #....but who cares, its not like it matters
robo519
robo519
Canada
g30ffr3y
