subs hits on power down.
truckbump44
sorry if this has been discussed but i looked and looked and found nothing really. i really just need to know if its an AQ thing? i recently installed a brand new AQ 1200 and when i shut the radio off after playing at high volume it burps, also if i put the radio volume on 0 after playing it loud the samething happens. old hfi 3000d never burped?
07 wrx
big 3 done in 0awg
rcas are streetwires zn5s ran atleast 24" away from power
ground is tight on car seat body bolt. thinking about running 0awg back to battery?
any helps thanks in advance.
Turn on/off thump. No biggie. Gonna hurt your score in SQ judging though.
Happens when the HU turns off or on before the amp does.
i know it not a big deal, just driving me nuts. so its just the amp turning off after the deck could i change this anyway?
it doesn't work like that. it's like a pump and is limited by the size of pipe. the small wire negates any benefit from the larger wire. more resistance on the smaller wire as well.
HOW IS THERE MORE RESITANCE ON THE INPUT? sorry for caps button has a mind of its own
BECAUSE IT IS A SMALLER WIRE AND A LONGER RUN (caps intentional)
A 1/0 HAS LESS RESISTANCE (MORE CONDUCTANCE, *******) THAN A 4 GA WIRE.
IF IT DIDN'T WORK LIKE THAT, WE'D ALL HAVE SMALL GAUGE POWER WIRES.
All grounds I've seen with a seat always were a bad ground. I'd try a new ground location. And try testing the ground out with ur dmm to see if it has a lot of resistance, best case scenario it will read 0. Just my advice and experience, good luck tho
ya ill do a test what should the highest resistance be around. i know to shoot for 0 but with a unibody i doubt ill get even close
truckbump44
truckbump44
Hickville Nh
QueSound15
