Subs hit no sound tho
  • 2
paul83085
USA
I thought i seen it on here before but i cant find it. So if you can find that post put it up on this post for me. But i have a jbl 600 and 2 edk's and all of a sudden they are hitting but no sound coming out of them at all. I checked the fuses even took the sub out that wasnt hitting first because there was one hitting with sound and one not even moving. I do not have them wired in parellel just 4 ohm load. Can someone help me
so what does this include in checking put a list up for me please and i will do w/e is on there tomorrow
check the wiring on the subs to the amp...make sure all positive's and negatives ultimately end up going to the positive and negative on the amp...
Most likely your ground. I've seen that happen, the sub looks like it's playing a 5 Hz note. If one piece of equipment doesn't have a good ground...
These are also very good drivers, some of the best bang for the busk on shallow mounts. DD Audio SL610-D2 10"...
5
512
Well, get Two then and try to share for peeks sake!! :poop: :ROFLMAO::ROFLMAO::ROFLMAO:
16
paul83085
paul83085
USA
Randy Savage
