Subs glued to box
You might try a heat gun and pry gently.Take your timewith a flat pry bar and hammer. Must have had a seal leakage and didnt want to remove the subs and make a new baffle which is cheap to do
Yeah. I vote heating and fishing line. Great suggestions. That's how we take cap block off retaining walls that have been adhered together. Should have thought of that in first place.
I'm going to try that sometimes this week. The guy I got them from had them all wired weird and I had to go in and wire them to 1 ohm but had to use the port to stick my hand in there. Long story short it took over an hour and I had to cut another hole then glue it back on the box
Sent from my SM-N920T using Tapatalk
Hammer a flat head screw driver under the basket in a few spots and pop those woofer right out the box. Easy as that. Done it a few time on painted enclosures where the woofers are stuck to the paint like glue.
Brahmas are nice. I have a 10" Mk1. Just a single 10 was enough for me.
19
907
663
16
562
Chalo_209
Chalo_209
Kingsport tn
Based
