Subs Broke Window Seal
Go to a glass shop and get some butyle rubber sealant or dow cornering 795. Silicone will produce rust and should never be used on bare metal. The dow 795 is what i would suggest as it stick to any surface and oddly enough is easy to clean off of a painted surface once it is dry by simply scraping with a finger nail. sounds wierd but regardless it holds better then anything. Or while there, ask what they suggest //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif (i used to have a glass shop btw http://www.cgiglass.com )
Are you shure the sub did it? I could care less, but Ive had windows leak on a 2 of my trucks with out subs.//content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
man the same thing happened to my ranger after i dropped in the RE's and it was not my window check the seal on your third brake light mine was dryrotted so i replaced it with industrial glass adhesive blacke rubber junk and then trimmed with an exacto knife... the light was leaking and the water settled on top of the window in the gutter where the window is stamped out into the back of the cab. The water then appeared to leak around the window. I hope this is a quick fix for you if this is what happened.
Yea im pretty sure b/c it never leaked at all until i dropped the subs in..........no i just found out in the car wash today that it is leaking right onto me...from the door seal now......not from the window though...(i think i fixed it though)
shit like that happens sometimes...nice avatar btw //content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif
My Ranger was blowing water in on the dash over the glovebox..
I was in cali so I would only see it like 2x a year..
but once it ran into the golve box & my Xover got wet //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
**** Fords..
that happened in my truck with 4 12's and 1600w, water leaked right on the amp and I heard a loud crack and I could see a small flame in the amp. Was probably my fault though I resealed it back in after being out for a bed cap. I got some butyl sealer and just filled in where it didnt look the best. Fine ever since
drifterman33
drifterman33
Hell (aka Guerin)
Lakota
