Subs are hitting without music on, help?
Mp5Jesse
The other day I hooked up my buddies amp to my subs since he wanted to test it. Turns out his amp was fried, and I hooked mine back up. After hooking up my amp i would turn my key on, and with the volume at 0 the subs would hit in quick bursts. I unhooked one rca at a time and made sure they were tight, then it started working correctly, but then i ended up snapping off a clip for the wire to go to my subs, so i diconnected it all.
Now I put everything back in after fixing the clip, and those same bursts kept starting. Tried the thing with the RCAs i mentioned but it didnt stop, so i threw in my new RCA's yet it still does it.
Any idea on why they would be doing this?
As in from the Amp to the Subs?
Only thing i did when i swapped was pull the RCA's Power, and remote wire, then used his speaker wires to my box.
Swapped everything back to mine how i had it before, which is why this makes absolutely no sense to me. Since it worked perfectly fine before I tested his amp.
Mp5Jesse
Mp5Jesse
Pittsburgh, PA
Mp5Jesse
