sub wont move in freeair, help?????
mile098
ohhh noeeeesss
yes, i know but its not fried, hear this out.....its jbl p1222, dual 2 ohms...
i took a regular 1.5 v battery checked each coil separately it moves, parallel moves, series u hear the cabels thouching the poles but the bat is too weak to move it @ 4 ohms..
i hook it up to an ampRF bd1000.1(breaking in),and play pink noise...i feel the suspension vibrating under my finger, but no movement...started off low volume gradually got to 27 on 9855 and 3/4 gain on the amp...i hear the noise but it just wont ****ing move in series...tried it with music, and i hear it(other speakers disconnected) but the mother****er wont move...and in freeair at that much power the amp should have killed it....
btw the amp worked perfectly fine on my mb quart(unhooked it to break this one in)...WTF is wrong with it???and yes i did check the cabels, several times...plus/minus,plus/minus and in the terminal together...
pls help out:crap:
^^on my dmm i have settings for resistance in 2000k,200k,20 k,2000 and 200 ohms...i guess i set it to 200...where do i put the needls???just press it on the terminals or???
Put your sub face down on a table and then take the measurement of one coil with your meter leaving the other unconnected. Try not to press on the terminals - any movement of the sub will cause the reading to go off. Polarity does not matter with DC resistance tests, which is what you are doing.
Then do the second coil.
For "dual 2 Ohm' subs you should get a reading anywhere from ~1 - 2 Ohms per coil.
mile098
ohhh noeeeesss
mile098
dubrovnik, CROATIA
nismos14
