Sub wiring
  • 4
cgraz1187
Before anyone asks yes, I viewed the sub wiring diagrams at RF..
but.. what I wanted to know is that If I have two 4ohm speakers and a mono amp.. and I wire up the voicecoils to run a 1ohm load, when the wires are connected to the one input on the amp does that change the impendence. Stupid question I know, but I would rather ask now then be sorry later.
Thanks in advance.
Dual 4 ohm subs wired in parallel will get you to a one ohm load. When you connect them to the amp, it will see a 1 ohm load. The amp won't change the impedance.
I think the only time it changes it (but really doesnt) is if you have a 1 channel mono block amp with 2 pos and 2 neg speaker inputs.... i think its wired in parallel at the amp so it still sees a 1 ohm load....
A little DAP will do ya, drill, feed & seal, done.
736
two d2 subs can be wired to .5 or 2 or 8 ohms not 1 heres how to wire subs...
Hello I'm happy to have came across this forum as I'm hoping someone will help with this little bit of confusion I'm having and maybe save me some...
This might be easy for some but i've only had it wired as a 4 channel. Theres a 2 channel to 4 channel switch and 4 rca's on the other side of the...
Having to adjusting the sub input sensitivity depending on the music, would be reason enough for me to go with the RCA cables. It does seem odd...
cgraz1187
cgraz1187
Scranton PA
Jdm94Coupe
