Sub Wiring Not Making Sense
what size alt.
370 amp
what size battery
2 of XS Power D3400 (12volt 3,300 amp)
how many batterys?
what size power wire?
mostly 1/0 gauge
did you do the big 3 yet?
yes
what car ?
2007 fords focus zx4 w/o stock sub
is that your system?if so your good.
but so you know, thats over board for what you have.
im about 6000 rms with all my amps and im only running 300amps of alts and a few batterys and im good.
but dont worry about it as you already have it.
The only real part I'm worried about is the factory wiring. Like, if somehow the 2 runs of 1/0 from alt to my main battery doesn't work of something, then the factory wiring will short or melt. That factory fuse only handles like 170 amps max.
not sure what your saying??
but you should have both ends of them 1/0 runs fused.
and keep all power wires ( amps/batterys ) away from other wires. and keep them away from remote turn on, rca.
The factory starter wires is what I was referring to. But that is useful info.
What about this 2 dvc d4 1 ohm
Is this a legitimate way to wire to 1ohm everything's in parallel right so should work????
bs199sg
bs199sg
United States
els1989
