Sub Wireing
Wragold
Is this ok for the negative wire. I cant get it in all the way.
probably, but i would give it another go...
you could try to remove som of the copper in each wire, and then solder it together.... this will form a solid and soft lump wich is easy to sculpt...
Yeah I dont have a soldering gun so do you think it will work if i just take off more wire and get it to fit?
take more insulation off, remove copper, and make a tightly wrapped straigth line... do this so that you have about 50 % of each wire in the connector.... avoid the V shape on the wires...
Wragold
Wragold
Charlotte, NC
Wragold
