SUB volume problem
Okay, couple of suggestions With this being a sealed enclosure. Play with the position of the enclosure. Sub firing back, sub firing forward, and...
Check your grounds! Both head unit and amp. I had this issue before and it was a grounding issue. Ground wire made enough contact to play low...
181
smithc119
smithc119
Tuscaloosa, AL
smithc119
SPLBassJunkie
    May 21, 2024
    May 20, 2024
