Sub suggestions... parameters included...
Suggestions on a pair of subs for best SQ… what would you choose?
Common to all choices...
¾” MDF box with 2 X 1ft^3 sealed compartments
(Recommended sealed enclosure for all of these subs is ~1ft^3)
Kicker 600.1 amp birthed at 745 watts RMS @ 2ohms 14.4v
Suggested sub pairs…
(Other suggestions are welcome)
IDMAX 10v3 D2 (10’ Dual 2ohm)
Fs 20.4hz
Qes .416
Qms 2.16
Qts .349
Vas 3.07ft^3/87 liters
Xmax 24.6mm (one way)
Sd 388cm^2
Spl 90.9 (1watt/1meter)/85.9db (2.83v)
Pwr 1000watts RMS
PG Titanium Ti 12 (12” Single 4ohm)
Fs 27.22hz
Qes .438
Qms 6.83
Qts .412
Vas 1.67ft^3/47.25 liters
Xmax 18.1mm (one way)
Sd 490cm^2
Spl 86.5db (2.83v)
Pwr 500watts RMS
IDQ12 D2 V.2 (12” Dual 2ohm)
Fs 19hz
Qes .271
Qms 4.59
Qts .256
Vas 5.04ft^3/143 liters
Xmax 13.5mm (one way)
Sd 530cm^2
Spl 90.2db (1watt/1meter)/NO 2.83v GIVEN
Pwr 350watts RMS
Elemental Designs 13Ov2 D2 (12” Dual 2ohm)
Fs 21hz
Qes .3
Qms 3.3
Qts .28
Vas 6.22ft^3/176 liters
Xmax 18.3mm (one way)
Sd 545cm^2
Spl 89db (1watt/1meter)/NO 2.83v GIVEN
Pwr 600watts RMS
Thanks!
I have only heard the IDmax, the lower end ID's probably sound good but they look cheap with those stamped metal baskets and those old school terminals the require Radio Shack connectors.
I'd look into the IDv3 along with (or rather than) the IDQv2.....IDv3 actually has more Xmax and supposedly better SQ than the IDQv2. And the IDv3 has the spring loaded terminals //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif The IDQ is supposed to be undergoing another redesign currently.
there isnt a real weak link in any of your choices but i would do a max in a heart beat if you had a lil bigger amp. still though nothing really bad there if you are thrifty the eds are a good choice and anywhere in between
Well I broke down and called Eric at ID and ask him his opinion. I think he was shootin' straight with me. Anyway... he tells me it's real close between the IDMAX 10v3 and the IDQ 12v2... but the IDMAX 10v3 would in fact play a little lower with a tad more output than the IDQ 12v2... considering the power I have.
It just seems like the 10's would be a little better controlled therefore maybe a little tighter than the 12's... yet I'd still have the at least the same output (maybe more) with at least the same low end extension (maybe lower).
I kinda got that feeling... he seemed to be on the up and up. We talked for quite a while and even got into some people we have known in the business for a long time. I felt pretty good after talking with him that I shouldn't be disappointed. Plus I'm in the process of getting set up with them as a dealer so he knows his honesty is important to me. Of all things... we have zero ID dealers in Alabama. I suppose that will be good that I'm the only one if someone from Bama calls in for a dealer around these parts.
Hey 80INCHES... can't help but to notice the EPICENTER plug... have you ever tried the PG BASSCUBE?
I mainly want to improve on this Kicker 12 L5... at first listen I was marveled at how hard it hit but after some more serious listening I was not impressed with the SQ. Even my last JL 12W6v2 was better than the Kicker. I don't play it that loud so SQ is more important.
a fluffier box would do it wonders with an alignment of .7 but it wont get open and airy like the id subs will.
Sonnie
Hillbilly
Sonnie
L. A. . . . . . . . . (Lower Alabama)
audiolife
NorthFramingham
    Jun 30, 2026
