Sub stopped playing need help
trabadoor22
I'm hoping to get some help to figure out why my sub won't play. It was working fine, then just stopped playing. I checked connections and they are all good. The amp's fuses are good. I have a fuse for a distrobution block and can't really tell if it's blown or not. It's one of those mini anl fuses which is black in the middle so I can't see it clearly. I also have another amp hooked up for the highs on the distrobution block with another fuse and that is working fine. The grounds go to a ground distrobution block to a single ground. The sub looks fine, however I don't know too much about the mechanics of a sub. I just bought a multimeter and would like to check the amp and sub, but not sure how to do this. Any suggestions, thanks.
Ok, update. I checked out the sub and no funky noises and it looks fine. I checked the voice coils with a multimeter and they both read roughly 2 ohms which is what they are. I connected the sub to my other amp which I know works and still no sound. I double checked the connections again and everything is fine. I called the manufacturer and they said the tinsel leads may be broken, but they seem fine although I can't see where they go beyond the spider. So my conclusion is that the sub is blown even though I see no evidence of it other than it won't play. I will most likely just purchase a new sub, however I just was hoping for more proof the sub is blown so I don't spend my money on a new sub for no reason. If there are any other tests I can do to figure out what is wrong with it I would appreciate it. Who knows, maybe I can get it fixed. Thanks.
trabadoor22
trabadoor22
Macedon, NY
trabadoor22
vegang
vegang
