Sub Selection/Comparison Help
Im looking to upgrade my stock rear 6.5 speakers to some subs but im not sure which one will produce the "Lowest and Loudest" bass
Ive narrowed it down to a pair of Kicker CompVT 08CVT652-$150 or a pair of JL 6W3V3-8-$260
Heres a comparison
http://www.crutchfield.com/App/Product/CompareTo.aspx?g=520&cc=01&compareItems=01|2068C65VT4&compareItems=01|1366W3V34
And manufacture pages
JL-http://mobile.jlaudio.com/products_subs.php?series_id=29
Kicker-http://www.kicker.com/comp_vt
Ill probably push them off of a Power Bass ASA-300.2x ran Mono
SPECIFICATIONS:
• 4 ohm Power : 75W x 2
• 2 ohm Power : 150W x 2
• 4 ohm Mono Power : 300W x 1
• Peak Power : 600W
• Total Harmonic Distortion :
• Frequency Response : 20Hz - 22,000Hz
• S/N Ratio : >94 dB/W/M
• Damping Factor : >150
• Input Sensitivity : 0.5 - 4.0 volts
• Crossover Slope : 12 dB
• High-Pass Crossover Freq : 40Hz - 250Hz
• Low-Pass Crossover Freq : 40Hz - 250Hz
• Variable Subwoofer EQ : 0/+18 dB
• Subwoofer EQ Frequency : 40Hz
• Dimensions : 7.8" x 9.3" x 1.9"
I'm looking for a dedicated 6.5" sub not a **** good Mid bass-SRRY
Any help on this would be great, thanks
why not go to PartsExpress and look at Tang-Band's 6.5" Subwoofers.... very very good little drivers, affordably priced and lots of good reviews....
and if you're wanting to go to dedicated subwoofers in the factory locations you'd best be sure to use sound deadening and mount them in some good MDF rings to be sure to get the best sound, no matter what you choose to buy installation makes or breaks the outcome.... also, unless the speakers are dual 4 or single 2 ohm coils you won't be able to bridge them to that amplifier.....
Ive looked at those and if i remember right they are too deep im going to put them in the stock locations of a 99 tacoma xtra cab similar to this
images%3Fq%3D93%2Bpickup%2Btoyota%2Brear%2Bspeakers%26ndsp%3D18%26hl%3Den%26sa%3DN%26start%3D54%26um%3D1
If i go with the JL ill get the 8ohm sub and run them in parallel
and if i go with kicker ill get the 2ohm model and run them in series
i think thats the right order
Could check out the Elemental Designs E3.6 at edesignaudio.com I think they're on sale right now and I'd put money on that walking all over the Kickers. Probably similar to the JL's but for way less $$.
bad03ranger
Get Some *****
bad03ranger
Reidsville, North Carolina, United States
bad03ranger
