Sub recommandation
Xprime4
****in' canadian
I realize the fiQ18 ain't really what I expected. I do love how it hit low, but he's also really lacking in the upper range of what i want my substage to do. It lack output in the 50-80hz range so sometime, bass line just cut out were they shoudln't. I also tough it would sound nicer, but i haven't heard alot of "sq" sub in my life. Maybe i'm a little more into spl.... type r i had in the car prior were loud around this area
I want my next one to be 60spl/40sq and be able to take an bxi2006 at 1ohm without trouble. It will be ported for sure. I'll change car soon so i'm not sure i want a 15 or a 18 yet.. It need to be LOUDER than a fiQ 18inch... so yeah loud from 30-80hz.... without dropping before those freqs like the q.
I won't be buying now, just starting to look into alternatives //content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif
Well i expect that answer.... does the bl or btl play really play higher ? I guess i can't tune a Q at 35hz and expect it to play hard till 80hz
I would try adjusting your current enclosure to higher tuning to see if it gains output at higher frequencies. How much port area you have?
I would move past FI if you are looking for loud in upper frequencey. RE MX is not going to be your answer either. AQ HDC3s are worth considering, but I would really look into a 15" Nightshade. The amp you have will not phase it, it still sounds goods, and plays upper frequencies will also.
Yeah the Aq Hdc3 seems to get a lot of attention. Will it be a lot louder than the Q overall? how is it hitting the 20-40hz range?... even if i want to upper bass, i love low hitting bass //content.invisioncic.com/y282845/emoticons/cool.gif.3bcaf8f141236c00f8044d07150e34f7.gif
Xprime4
****in' canadian
Xprime4
Quebec, Canada
williambrea
