Sub problem. Please try to help me if you can
  • 5
Jakerrr
When I have my sub on volume 20, its pretty freakin loud, even though the cone looks like its not even moving. Pretty crazy... But when I turn it up to around 27 or higher (out of 35), the screws loosen and the sub starts rattling like crazy and jumping around. Even is causing the box to flex and jump a bit. There really is a ton of output id say around 145 db somewhere around 39 hz but how do I keep these screws in place???! I've tightened them as much as possible they just seem to loosen up when I surpass 27/30 volume.
correct size screws? i made that mistake with my box, used a size screw just under the size i pre drilled, simple fix but hard to discover
I posted on your thread about your sub options btw. But no they're definitely the right size, the sub is just so loud it's about to rip the box to shreds it seems but it has to be due to the screws...
---------- Post added at 11:45 PM ---------- Previous post was at 11:44 PM ----------
Does anyone use certain types of screws for this problem? or glue
Like stated above,use bigger screws.or better yet t-lugs and screws or bolts.also you should anchor the box somehow so it does not bounce around and jump.
Thanks that should help ill just try some beefy screws I guess
Using a Y RCA to split signal from amp to amp to give both amps the signal they need from the HU and subs in different /separate enclosures tuned...
648
Easy fix, If your DSP has a single mono output, split it with a Y and run both to the sub. In my experience, even though the sub amp has two...
Fully test it without the ACR-1. TBH it sounds like an amplifier issue. Try connecting your phone direct to the amp via a 3.5mm to RCA cable. If...
697
That does sound similar to what mine does, I'll take a video and post it this weekend so you guys can weigh in.
23
5K
240
Jakerrr
Jakerrr
Lexington, SC
Jeffdachef
    May 16, 2024
    May 16, 2024
