Sub positioning / Amp mounting
steve2191
8
Roc
I have a single JL 12in ported in the same direction as the sub points. In my trunk, which way should i face the sub for full potential.
Also what type of screws/how would i mount the amp
velcro is fine for the testing phase, but it certainly won't hold it in an accident or prevent thieves from easily removing it. always use brackets and screws to keep the gear secure.
don't use drywall screws in a car, ever. drywall screws are for drywall. Use construction grade screws, tamper resistant screws, etc. self tapping screws are for securing brackets to the metal in your car. i usually try to use square bit or torx bit as well.
i prefer to mount amps to a separate carpeted board, then secure the board to the vehicle so it is out of the way on a side. that way i can easily move the sub box around, or remove it completely, as needed. some will mount the amp to the back of the rear seat, but still use a board. you don't want to mount an amp directly to car metal.
sub positioning will determine performance. the best place to start is the one with the least amount of destructive phase interference. usually, this is in the rear corner of the trunk, facing back or to the side. don't adjust it until it's loudest, adjust the position until you get the most balanced, dynamic, and tight sound.
I have a Sonata with a decent sized trunk..currently I have the sub/port facing up towards the top of the trunk with the amp still on the ground.It sounds good but i would like the amp in a permanent position.
steve2191
steve2191
Roc
steve2191
