Hi all need your wisdom on this one! I'm old but new to the powered sub set up! here's whats up! purchased an amp and 8" sub,car is a convertible,sub will be mounted in storage area behind drivers seat,not the perfect choice of location,but trying to make it work! not much room to work with and trying to keep a clean look,don't want a big box or speaker in trunk! this is what I've done so far.
have the sub mounted to storage compartment door and now I need help on porting the compartment,the speaker I got fits nicely and is from Sundown audio and its made for small spaces and needs porting to work right. amp should be here next week and will be located in truck where battery is,just need to know where to port and how to do it??? was thinking of using round tube and hole in front,the size of enclosure is 16 wide 14 deep and 8-9 high,approx 1.3 cubic feet. I have a donner storage compartment ,so its easy to work on it out of the car,will be keeping my original one in the attic, here's pictures!
here's spec's on speaker and amp,should be around 200watts rms.
RE: 3.927 ohms
Fs: 43.59 Hz
Qes: 0.643
Qms: 4.404
Qts: 0.555
Le: 2.75 mH
Vas: 7.22 L
BL: 13.023
NA Cms: 131 uM/N
Mms: 101 grams
Sens: 81.53 1w/1m
Xmax: 10.5mm one-way linear
Power: 200 RMS
Enclosure reccomendations
Sealed: 0.25 ft^3
Ported: 0.5-0.6 ft^3 @ 35Hz
Displacement: 0.05 ft^3
Outside Diameter: 8 1/4"
Depth: 4 9/16"
Cut-Out: 7 1/4"
Amp is a
Precision Power PPI BK650.1D
650W RMS Monoblock Class D Black Ice Series Car Amplifier
Power Specifications - Subwoofer Channel
RMS Power @ 4 ohms
240 watts x 1 channels
RMS Power @ 2 ohms
450 watts x 1 channels
RMS Power @ 1 ohm
650 watts x 1 channels
Amplifier Specifications
Amplifier Series
Black Ice (Precision Power)
Amplifier Class
D
Number of Channels
1 - Mono
Total RMS Power Output
650 watts
Maximum Input Gauge Size
4 AWG
Minimum Impedance Unbridged
1 ohms
THD at Rated RMS Power
.5%
Speaker Level Inputs
No
Preamp Outputs
No
Built-in Crossover
Low-pass (LP)
High-pass (HP)
Low-Pass Crossover Frequency
35 - 250 Hz
Subsonic Filter
10 - 50 Hz
Bass Boost
0 - 12 dB
Bass/Gain Remote
Yes
Fuse Rating
RE: 3.927 ohms
Fs: 43.59 Hz
Qes: 0.643
Qms: 4.404
Qts: 0.555
Le: 2.75 mH
Vas: 7.22 L
BL: 13.023
NA Cms: 131 uM/N
Mms: 101 grams
Sens: 81.53 1w/1m
Power: 200 RMS
Sealed: 0.25 ft^3
Depth: 4 9/16"
Cut-Out: 7 1/4"
Amp is a
RMS Power @ 4 ohms
RMS Power @ 2 ohms
RMS Power @ 1 ohm
Amplifier Series
Amplifier Class
D
Number of Channels
1 - Mono
650 watts
4 AWG
1 ohms
.5%
No
Preamp Outputs
No
Built-in Crossover
Low-pass (LP)
High-pass (HP)
35 - 250 Hz
Subsonic Filter
10 - 50 Hz
Bass Boost
0 - 12 dB
Bass/Gain Remote
Yes
Fuse Rating
