You would have a dual 4 ohm sub then , Which is right for your amp , You need to wire your sub for a 8 ohm load and when you brige your amp it will see 4 ohms , That is perfect and your amp will love you , If you have it at a 2 ohm load your amp may be shutting off due to being to low of a ohm loadOriginally posted by wintermute 117 shite - i just noticed the specs on the Infinity Kappa perfect say it runs at 2 or 8 ohms.... would that change things? if so how would i wire things now? series?
