Sub heat and wire
Beastastic
FL
Is is bad if my sub is getting warm, but I don't smell burning coil? Seems like it gets warm easy and when I turn the gain down its not nearly as loud and not pushing the sub like I want, but my voltage stays above 13v always so I dont think im clipping it. The amp is an AQ 2200 and i have it at 1 ohm. Also, what size speaker wire should I use? Right now im using 14 gauge speaker wire. Should I be using like 10 gauge, and is this possibly why the sub is getting hot? I dont see how 10 gauge wire is supposed to work cause it wouldnt fit in the terminals of the sub when I have to wire it up when I have to put 2 runs in each terminals for 1 ohm.
here are my settings:
gain - 3/4
Sub Sonic - 20
Bass Boost - 0
LPF - 110
HPF (on HU) - off
When im driving my voltage stays 13-14v and when i play a song with really low notes it gets hotter quicker. I dont smell any coil burning unless i have it cranked when im just at idle and my voltage drops
the sub is going to get hot no matter what brand
its doing work
work = heat
your voltage sounds to be ok
14ga wire to your sub is more than enough
people like to say to use 8ga but that will be way to much
Beastastic
Beastastic
FL
blazeplacid
