sub gets hot to fast?
Its mounted on the back of my rear seat in my car
This could mean alot of different things.
First two things that come to mind
1. Bad ventilation - Where is the amp mounted?
2. Amps Clipping - Needs the gains adjusted correctly
No the seat is usually folded down and the sub is on the other side of the trunk. But i just noticed it get very hot today could the amp be going bad or something? But today was one of the first days of warm weather if that matters
Let me guess though. The box is right next to it, covering it? Very little ventilation? Or does it get hot with the seat folded down? If so, the amp is clipping. Get everything adjusted correctly.
Today my 4 channel amp went into protect mode today and it has never done that before i think there is something else wrong. what are things i can look at?
Apparently you have some serious voltage problems. Things to look at:
1. Has the Big 3 been done? If not, do it.
2. How big is your factory alternator? Less than 130 amps, need to look at adding a secondary battery or buying a higher output alternator.
3. What is voltage at the battery?
4. What is voltage at the amplifiers?
5. How are your grounds on both amps? Ground down to BARE metal?
6. What size power wire are you using? Also, what size ground wire are you using?
But seems to me that you are getting some serious voltage drop. Causing the t1000 to send a clipped signal to the sub and now causing the 4 channel to go into protect mode due to low voltage. RF t1000 is a current hungry lil fucker. I had the t1500.1bd and had to run two extra batteries due to the current it pulled. At the time I only had a 140amp alternator.
Brandon9
Brandon9
michigan
TreyE
michigan born
    May 14, 2026
michigan born
    May 14, 2026
