I am thinking about getting an Arc Audio KAR sub and the recommended enclosure is 1 cu ft and power handling is 250W RMS.
What happens if the enclosure is smaller than recommended sealed 1 cu ft, say 0.8 to 0.9 cu ft? I am assuming that it would limit movement of the of cone.
My amp will put out 350W RMS but I think as long as I'm not going crazy with the volume knob and keep the gains down, I think I should be ok. Is this correct?
Now what happens if I have the sub using that amp in a 0.8 cu ft enclosure?
