tooshort_128 10+ year member CarAudio.com Elite 640 0 Sterling, VA Feb 27, 2012 #16 It's always a good idea to use the same gauge wire for both power and ground.
OP devast8r3436 10+ year member Senior VIP Member 281 0 Heber Springs, AR Feb 28, 2012 Thread Starter #17 Well what's throwing me off is the power will be 4 gauge to a distribution block then broke down into 8 gauge.
IonRL205 10+ year member DJ h4z4rdes 2,513 30 Abilene, Texas Feb 28, 2012 #18 You should be fine with using 8 gauge grounds.
OP devast8r3436 10+ year member Senior VIP Member 281 0 Heber Springs, AR Feb 28, 2012 Thread Starter #19 Thank you. What about the turn on? splice it or just run it to one amp then the other?
J jokers10 10+ year member Member 52 0 73521 Feb 28, 2012 #20 Normally one, and then to the other is fine, but sometimes head units can put out too weak of a signal to turn on both amps. In those cases you just need to wire up a simple relay.
